MAGNETICS
VM!
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0076381A7
Kool Mµ Hƒ
2
AL (nH/T )
Permeability (µ)
60
43 ± 8%
Lot
Number
XXXXXX
Core Marking
Part
Inductance
Number
Grade
76381A7
N/A
Dimensions
Uncoated
Coated Limits
(mm)
(in)
(mm)
(in)
OD (A) 17.27 0.680 18.03 0.710
max
ID (B)
9.65
0.380
9.02
0.355
min
0.250
7.11
0.280
HT (C) 6.35
max
Electrical Characteristics
DC Bias
Voltage Breakdown
Watt Loss @
wire-to-wire min
100kHz, 100mT min (Oersteds)
3
(VAC)
50%
(max, mW/cm ) 80%
450
45.0
100
>2000
Break
Strength
(min, kg)
28.1
Black
Packaging
Bulk Pack: 4 bags/box
Box Qty = 2000 Pcs
Physical Characteristics
Window
Cross
Path
Area, WA Section, Ae Length, Le
2
2
(mm)
(mm )
(mm )
63.8
23.2
41.4
Winding Information
Winding Length per Turn
Wound Coil Dimensions (mm)
19.6
OD
Winding
Winding
(mm)
(mm)
40% Winding Factor
Factor
Factor
10.1
HT
0%
23.2
40%
28.0
24.9
Max OD
Completely Full
Window
20%
25.6
45%
28.6
16.3
Max HT
2
25%
26.2
50%
29.3
Surface Area (mm )
30%
26.6
60%
30.8
990
Unwound Core:
35%
27.4
70%
32.4
1400
40% Wound:
Coating
Color
Volume Ve
3
(mm )
960
Weight (g)
6.3
00
Temperature Rating
Curie Temp (°C):
500 °C
Coating Temp:
200 °C
(Continuous, up to; °C)
Notes:
Typical DC Bias Performance
50.0
80%
AL (nH/T2)
40.0
30.0
50%
20.0
10.0
0.0
200
300
A·T
400
500
600
很抱歉,暂时无法提供与“0076381A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.057131+3.50500
- 10+18.6032410+2.40988
- 25+15.8416925+2.05215
- 50+13.9273450+1.80416
- 100+12.15163100+1.57413
- 250+9.98959250+1.29406
- 500+9.58368500+1.24148
