0077059A7
0077059A7
    MAGNETICS(美磁)
    有涂层 Kool Mu 铁氧体磁芯磁环 型 长度 宽 0.930"(23.62mm) 直径 0.330"(8.38mm) 高
0077059A7 数据手册
0077059A7 MAGNETICS AL (nH/T2) 60 43 ± 8% Part Number 77059A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 22.86 0.900 23.62 0.930 max ID (B) 13.97 0.550 13.34 0.525 min HT (C) 7.62 0.300 8.38 0.330 max Bulk Pack 4 bags/box Box Qty= 1000 pcs Physical Characteristics DC Bias min (oersteds) 80% 39.0 Lot Number XXXXXX Uncoated Electrical Characteristics 750 Core Marking Kool Mµ Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) >3000 39.0 139 31.7 56.7 1,800 11.28 50% 87.0 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 27.0 30.5 31.3 32.0 33.1 40% 45% 50% 60% 70% 33.9 34.9 35.9 38.0 40.4 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 25.7 12.4 32.6 19.8 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 1,600 2,400 Typical DC Bias Performance 45 40 80% 35 AL (nH/T2) 30 50% 25 20 15 10 5 0 0 50 100 150 200 250 300 350 400 450 500 A·T Revision 10/6/2021
0077059A7 价格&库存
很抱歉,暂时无法提供与“0077059A7”相匹配的价格&库存,您可以联系我们找货
0077059A7
  • 1+20.176791+2.61326
  • 10+13.9724810+1.80969
  • 25+11.9352025+1.54582
  • 50+10.5275250+1.36350
  • 100+9.21922100+1.19406
  • 250+7.62841250+0.98802
  • 500+6.82745500+0.88428
库存:2682
