110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0077076A7
Kool Mµ
Permeability
(µ)
60
Dimensions
AL
2
(nH/T )
56 ± 8%
Uncoated
max (mW/cm3)
50%
87
Winding Length Per Turn
(mm)
Winding
Factor
(mm)
(in)
(mm)
(in)
1.410
36.70
1.445
max
ID (B)
HT (C)
22.35
10.46
0.880
0.412
21.54
11.35
0.848
0.447
min
max
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
Wa(mm2)
Cross
Section
Ae (mm2)
3000
80.0
364
67.9
(mm)
0%
37.9
40%
48.8
43.4
45%
50.5
25%
44.7
50%
52.0
30%
46.0
47.6
60%
70%
55.4
59.2
Path
Volume Ve Weight
Length
(g)
(mm3)
Le (mm)
89.7
6,090
OD
HT
41.1
18.0
Max OD
43.3
Max HT
26.8
40% Winding Factor
Completely Full Window
Notes:
Surface Area (mm2)
Unwound Core
40% Winding Factor
3,500
5,500
80%
50
50%
40
30
36.3
Curie Temp:
500°C
Coating Temp (Continuous up to):
200°C
Typical DC Bias Performance
60
AL (nH/T2)
Cardboard cut-outs
Box Qty= 220 pcs
Temperature Rating
Wound Coil Dimensions (mm)
20%
35%
Black
Packaging
35.81
Winding Information
Winding
Factor
Coating
Color
Physical Characteristics
DC Bias min
(oersteds)
80%
39
750
Coated Limits
OD (A)
Electrical Characeristics
Watt Loss
@ 100kHz, 100mT
Core Marking
Part
Inductance
Number
Grade
77076A7
N/A
Lot
Number
XXXXXX
400
600
800
1000
A·T
Revision
10/8/2021
很抱歉,暂时无法提供与“0077076A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+45.245011+5.84840
