0077109A7
0077109A7
    MAGNETICS(美磁)
    有涂层 Kool Mu 铁氧体磁芯磁环 型 长度 宽 2.285"(58.04mm) 直径 0.585"(14.86mm) 高
0077109A7 数据手册
0077109A7 MAGNETICS AL (nH/T2) 125 156 ± 8% Part Number 77109A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 57.15 2.250 58.04 2.285 max ID (B) 35.56 1.400 34.75 1.368 min HT (C) 13.97 0.550 14.86 0.585 max Cardboard cut-outs Box Qty= 90 pcs Physical Characteristics DC Bias min (oersteds) 80% 14 1000 Lot Number XXXXXX Uncoated Electrical Characteristics Watt Loss @ 100 kHz, 100mT max(mW/cm3) Core Marking Kool Mµ Permeability (µ) Dimensions ` 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 35 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 107.0 948 144 143 20,700 130 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 53.0 61.9 64.3 65.8 68.7 40% 45% 50% 60% 70% 71.0 73.2 76.0 81.3 87.1 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 63.5 25.9 81.3 44.4 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 7,700 13,000 Typical DC Bias Performance 160 140 80% 120 AL (nH/T2) 100 50% 80 60 40 20 0 0 100 200 300 400 500 600 A·T Revision 9/30/2021
0077109A7 价格&库存
很抱歉,暂时无法提供与“0077109A7”相匹配的价格&库存,您可以联系我们找货
