0077439A7
MAGNETICS
AL
(nH/T2)
60
135 ± 8%
Part
Number
77439A7
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(mm)
(in)
(mm)
(in)
OD (A)
46.74
1.840
47.63
1.875
max
ID (B)
24.13
0.950
23.32
0.918
min
HT (C)
18.03
0.710
18.92
0.745
max
Cardboard cut-outs
Box Qty= 105 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
39
Lot
Number
XXXXXX
Uncoated
Electrical Characteristics
750
Core Marking
Kool Mµ
Permeability
(µ)
Dimensions
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
233
427
199
107
21,300
120
50%
87
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
62.1
68.2
69.7
70.9
72.7
40%
45%
50%
60%
70%
74.1
76.0
77.6
81.2
85.4
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
51.2
26.0
63.8
38.7
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
6,900
9,600
Typical DC Bias Performance
140.0
120.0
80%
AL (nH/T2)
100.0
80.0
50%
60.0
40.0
20.0
0.0
200
300
400
500
600
700
800
900
1000
A·T
Revision 10/6/2021
很抱歉,暂时无法提供与“0077439A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+82.345061+10.62273
- 10+55.4478910+7.15292
- 25+46.5059825+5.99939
- 50+40.2880150+5.19726
- 105+35.37916105+4.56401
