0077548A7
0077548A7
    MAGNETICS(美磁)
    有涂层 Kool Mu 铁氧体磁芯磁环 型 长度 宽 1.325"(33.66mm) 直径 0.450"(11.45mm) 高
0077548A7 数据手册
0077548A7 MAGNETICS AL (nH/T2) 125 127 ± 8% Part Number 77548A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 32.79 1.291 33.66 1.325 max ID (B) 20.09 0.791 19.46 0.766 min HT (C) 10.67 0.420 11.43 0.450 max Cardboard cut-outs Box Qty= 250 pcs Physical Characteristics DC Bias min (oersteds) 80% 14.0 Lot Number XXXXXX Uncoated Electrical Characteristics 750 Core Marking Kool Mµ Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 35.0 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) >3000 79.0 297 65.6 81.4 5340 34 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 37.1 42.1 43.2 44.4 45.9 40% 45% 50% 60% 70% 46.9 48.5 50.0 52.8 56.3 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 36.8 17.8 46.7 28.0 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 3,100 4,900 AL (nH/T2) Typical DC Bias Performance 140.0 130.0 120.0 110.0 100.0 90.0 80.0 70.0 60.0 50.0 40.0 30.0 20.0 10.0 0.0 80% 50% 0 50 100 150 200 250 300 A·T Revision 10/6/2021
0077548A7 价格&库存
很抱歉,暂时无法提供与“0077548A7”相匹配的价格&库存,您可以联系我们找货
