0077716A7
0077716A7
    MAGNETICS(美磁)
    有涂层 Kool Mu 铁氧体磁芯磁环 型 长度 宽 2.000"(50.80mm) 直径 0.530"(13.46mm) 高
0077716A7 数据手册
0077716A7 MAGNETICS Core Marking Kool Mµ Permeability (µ) AL (nH/T2) 60 73 ± 8% Inductance Grade N/A Coated Limits Coating Color Black Packaging (in) (mm) (in) OD (A) 50.80 2.000 51.69 2.035 max ID (B) 31.75 1.250 30.94 1.218 min HT (C) 13.46 0.530 14.35 0.565 max Cardboard cut-outs Box Qty= 90 pcs Physical Characteristics DC Bias min (oersteds) 80% 39 Part Number 77716A7 (mm) Electrical Characteristics 750 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 100 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 93.0 751 125 127 15,900 92 50% 87 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 49.5 57.4 59.6 61.0 63.5 40% 45% 50% 60% 70% 65.5 67.7 70.1 74.9 80.3 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 56.6 24.2 72.4 40.6 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 6,400 11,000 Typical DC Bias Performance 80 70 80% AL (nH/T2) 60 50 50% 40 30 20 10 0 0 200 400 600 800 1000 1200 A·T Revision 10/7/2021
0077716A7 价格&库存
很抱歉,暂时无法提供与“0077716A7”相匹配的价格&库存,您可以联系我们找货
0077716A7
  • 1+78.578061+10.17261
  • 10+52.9868710+6.85961
  • 25+44.4742425+5.75758
  • 90+33.8505990+4.38226
  • 180+33.51346180+4.33861
库存:1122
