0077737A7
MAGNETICS
AL
(nH/T2)
60
204 ± 8%
Part
Number
77737A7
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(mm)
(in)
(mm)
(in)
OD (A)
74.09
2.917
75.21
2.961
max
ID (B)
45.29
1.783
44.40
1.748
min
HT (C)
35.00
1.378
35.92
1.414
max
Cardboard cut-outs
Box Qty= 24 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
39
Lot
Number
XXXXXX
Uncoated
Electrical Characteristics
750
Core Marking
Kool Mµ
Permeability
(µ)
Dimensions
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
50%
87
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
2000
227.0
1,550
497
184
91,400
540
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
102
114
117
119
122
40%
45%
50%
60%
70%
125
129
132
139
147
Temperature Rating
Wound Coil Dimensions (mm)
OD
91.0
40% Winding Factor
HT
55.2
Max OD
102
Completely Full Window
Max HT 65.7
Curie Temp: 500˚C
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
19,000
33,000
Typical DC Bias Performance
220.0
200.0
80%
180.0
AL (nH/T2)
160.0
140.0
50%
120.0
100.0
80.0
60.0
40.0
20.0
0.0
400
600
800
1000
1200
1400
1600
1800
A·T
Revision 10/7/2021
很抱歉,暂时无法提供与“0077737A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+242.524541+31.30789
