110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0077932A7
AL
(nH/T2)
26
32 ± 8%
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(in)
(mm)
(in)
OD (A)
26.92
1.060
27.69
1.090
max
ID (B)
14.73
0.580
14.10
0.555
min
HT (C)
11.18
0.440
11.94
0.470
max
Cardboard cut-outs
Box Qty= 400 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
95
Part
Number
77932A7
(mm)
Electrical Characteristics
900
Lot
Number
XXXXXX
Uncoated
Dimensions
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
Core Marking
Kool Mµ
Permeability
(µ)
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
77.0
156
65.4
63.5
4,150
23.4
50%
205
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
37.5
41.1
41.9
42.8
43.8
40%
45%
50%
60%
70%
44.6
45.7
46.6
48.8
51.3
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
30.0
16.5
37.3
24.0
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
2,400
3,500
Typical DC Bias Performance
35.0
80%
30.0
AL (nH/T2)
25.0
50%
20.0
15.0
10.0
5.0
0.0
400
600
800
1000
1200
1400
A·T
Revision 1/25/2022
很抱歉,暂时无法提供与“0077932A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.000891+3.35419
