0078072A7
0078072A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 2.677"(68.00mm) 直径 0.787"(20.00mm) 高
0078072A7 数据手册
0078072A7 MAGNETICS Core Marking XFlux Permeability (µ) AL (nH/T2) 60 143 ± 8% Part Number 78072A7 Coating Color Inductance Grade N/A Coated Limits Brown Packaging (mm) (in) (mm) (in) OD (A) 68.00 2.677 69.42 2.733 max ID (B) 35.99 1.417 34.67 1.365 min HT (C) 19.99 0.787 21.41 0.843 max Electrical Characteristics Cardboard cut-outs Box Qty= 35 pcs Physical Characteristics DC Bias min (oersteds) 725 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 50 kHz, 100mT Max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 80% 50% 80 150 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 181.0 945 314 158 49,700 340 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 77.6 86.6 88.6 90.7 93.2 40% 45% 50% 60% 70% 95.1 98.0 101 106 112 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 74.7 37.4 92.7 50.6 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 12,700 19,000 Typical DC Bias Performance 160 140 80% AL (nH/T2) 120 100 80 50% 60 40 20 0 0 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 A·T Revision 9/30/2021
0078072A7 价格&库存
很抱歉,暂时无法提供与“0078072A7”相匹配的价格&库存,您可以联系我们找货
0078072A7
  • 1+173.267951+22.35201
  • 10+114.2039010+14.73260
  • 35+87.6289835+11.30437
  • 70+85.1311070+10.98213
库存:111
