110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0078076A7
MAGNETICS
AL
(nH/T2)
60
56 ± 8%
Inductance
Grade
N/A
Coated Limits
Coating
Color
Brown
Packaging
(in)
(mm)
(in)
OD (A)
35.81
1.410
36.70
1.445
max
ID (B)
22.35
0.880
21.54
0.848
min
HT (C)
10.46
0.412
11.35
0.447
max
Cardboard cut-outs
Box Qty= 220 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
80
Part
Number
78076A7
(mm)
Electrical Characteristics
725
Lot
Number
XXXXXX
Uncoated
Dimensions
Watt Loss
@ 50 kHz, 100mT
max(mW/cm3)
Core Marking
XFLUX
Permeability
(µ)
50%
150
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
80
364
67.8
89.8
6,090
43
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
37.9
43.5
44.8
46.0
47.6
40%
45%
50%
60%
70%
48.9
50.6
52.0
55.5
59.3
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 700˚C
40.2
18.4
51.1
29.6
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
3,400
5,700
Typical DC Bias Performance
60.0
50.0
80%
AL (nH/T2)
40.0
50%
30.0
20.0
10.0
0.0
400
600
800
1000
1200
1400
1600
1800
A·T
Revision 10/6/2021
很抱歉,暂时无法提供与“0078076A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.201771+5.70608
- 10+30.1947210+3.89789
- 25+25.5592725+3.29949
- 50+22.3457250+2.88465
- 220+17.05065220+2.20110
