0078097A7
0078097A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 4.055"(103.00mm) 直径 0.705"(17.91mm) 高
0078097A7 数据手册
0078097A7 MAGNETICS Core Marking XFLUX Permeability (µ) AL (nH/T2) 19 35 ± 8% Dimensions Part Number 78097A7 Inductance Grade N/A Coated Limits Coating Color Brown Packaging (mm) (in) (mm) (in) OD (A) 101.60 4.000 103.00 4.055 max ID (B) 57.15 2.250 55.75 2.195 min HT (C) 16.51 0.650 17.91 0.705 max Cardboard cut-outs Box Qty= 25 pcs Physical Characteristics DC Bias min (oersteds) 80% 290 215 Lot Number XXXXXX Uncoated Electrical Characteristics Watt Loss @ 50 kHz, 50mT Max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 575 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 181.0 2,470 358 243 86,900 565 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 82.2 96.8 100 103 108 40% 45% 50% 60% 70% 111 116 120 128 139 Temperature Rating Wound Coil Dimensions (mm) OD 112 40% Winding Factor HT 34.9 Max OD 136 Completely Full Window Max HT 55.1 Curie Temp: 700˚C Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 20,000 36,000 Typical DC Bias Performance 40 35 80% AL (nH/T2) 30 25 50% 20 15 10 5 0 0 2000 4000 6000 8000 10000 12000 14000 16000 A·T Revision 9/30/2021
0078097A7 价格&库存
很抱歉,暂时无法提供与“0078097A7”相匹配的价格&库存,您可以联系我们找货
