0078110A7
0078110A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 2.285"(58.04mm) 直径 0.585"(14.86mm) 高
0078110A7 数据手册
0078110A7 MAGNETICS AL (nH/T2) 60 75 ± 8% Part Number 78110A7 Inductance Grade N/A Coated Limits Coating Color Brown Packaging (mm) (in) (mm) (in) OD (A) 57.15 2.250 58.04 2.285 max ID (B) 35.56 1.400 34.75 1.368 min HT (C) 13.97 0.550 14.86 0.585 max Cardboard cut-outs Box Qty= 90 pcs Physical Characteristics DC Bias min (oersteds) 80% 80 Lot Number XXXXXX Uncoated Electrical Characteristics 725 Core Marking XFLUX Permeability (µ) Dimensions Watt Loss @ 50 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 107.0 948 144 143 20,700 150 50% 150 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 53.0 61.9 64.3 65.8 68.7 40% 45% 50% 60% 70% 71.0 73.2 76.0 81.3 87.1 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 700˚C 63.5 25.9 81.3 44.4 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 7,700 13,000 Typical DC Bias Performance 80 70 80% 60 AL (nH/T2) 50 50% 40 30 20 10 0 0 400 800 1200 A·T 1600 2000 2400 Revision 9/30/2021
0078110A7 价格&库存
很抱歉,暂时无法提供与“0078110A7”相匹配的价格&库存,您可以联系我们找货
