0078213A7
0078213A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 2.285"(58.04mm) 直径 0.585"(14.86mm) 高
0078213A7 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 0078213A7 MAGNETICS < AL (nH/T2) 90 112 ± 8% Inductance Grade N/A Coated Limits Coating Color Brown Packaging (in) (mm) (in) OD (A) 57.15 2.250 58.04 2.285 max ID (B) 35.56 1.400 34.75 1.368 min HT (C) 13.97 0.550 14.86 0.585 max Cardboard cut-outs Box Qty= 90 pcs Physical Characteristics DC Bias min (oersteds) 80% 48.0 Part Number 78213A7 (mm) Electrical Characteristics 700 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 50 kHz, 100mT max(mW/cm3) Core Marking XFLUX Permeability (µ) 50% 95.0 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 2000 107.0 948 144 143 20,700 155 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 53.0 61.9 64.3 65.8 68.7 40% 45% 50% 60% 70% 71.0 73.2 76.0 81.3 87.1 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 700˚C 63.5 25.9 81.3 44.4 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 7,700 13,000 Revision 9/30/2021
0078213A7 价格&库存
很抱歉,暂时无法提供与“0078213A7”相匹配的价格&库存,您可以联系我们找货
