0078440A7
0078440A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 1.875"(47.63mm) 直径 0.745"(18.92mm) 高
0078440A7 数据手册
0078440A7 MAGNETICS AL (nH/T2) 26 59 ± 8% Part Number 78440A7 Inductance Grade N/A Coated Limits Coating Color Brown Packaging (mm) (in) (mm) (in) OD (A) 46.74 1.840 47.63 1.875 max ID (B) 24.13 0.950 23.32 0.918 min HT (C) 18.03 0.710 18.92 0.745 max Cardboard cut-outs Box Qty= 105 pcs Physical Characteristics DC Bias min (oersteds) 80% 215 Lot Number XXXXXX Uncoated Electrical Characteristics 850 Core Marking XFlux Permeability (µ) Dimensions Watt Loss @ 50 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 233 427 199 107 21,300 145 50% 380 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 62.1 68.2 69.7 70.9 72.7 40% 45% 50% 60% 70% 74.1 76.0 77.6 81.2 85.4 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 51.2 26.0 63.8 38.7 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 6,900 9,600 Typical DC Bias Performance 60.0 80% 50.0 AL (nH/T2) 40.0 50% 30.0 20.0 10.0 0.0 0 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 A·T Revision 10/6/2021
0078440A7 价格&库存
很抱歉,暂时无法提供与“0078440A7”相匹配的价格&库存,您可以联系我们找货
0078440A7
  • 1+85.115441+10.98769
  • 10+57.2459510+7.38998
  • 25+47.9898225+6.19509
  • 50+41.5522350+5.36405
  • 105+36.75856105+4.74523
库存:10
