0078615A7
0078615A7
    MAGNETICS(美磁)
    有涂层 XFlux 铁氧体磁芯磁环 型 长度 宽 2.440"(61.98mm) 直径 0.984"(25.00mm) 高
0078615A7 数据手册
0078615A7 MAGNETICS Core Marking XFLUX Permeability (µ) AL (nH/T2) 26 82 ± 8% Inductance Grade N/A Coated Limits Coating Color Brown Packaging (in) (mm) (in) OD (A) 61.98 2.440 63.09 2.484 max ID (B) 32.59 1.283 31.70 1.248 min HT (C) 24.99 0.984 25.91 1.020 max Cardboard cut-outs Box Qty= 45 pcs Physical Characteristics DC Bias min (oersteds) 80% 215 Part Number 78615A7 (mm) Electrical Characteristics 850 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 50 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 193.0 789 360 144 51,800 390 50% 380 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 83.0 91.3 93.4 94.9 97.5 40% 45% 50% 60% 70% 99.5 102 104 109 115 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 700˚C 75.3 39.7 81.4 47.4 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 12,000 21,000 Typical DC Bias Performance 80 80% 70 AL (nH/T2) 60 50% 50 40 30 20 10 0 0 1000 2000 3000 4000 5000 6000 7000 A·T Revision 10/7/2021
0078615A7 价格&库存
很抱歉,暂时无法提供与“0078615A7”相匹配的价格&库存,您可以联系我们找货
0078615A7
  • 1+199.328171+25.71385
  • 10+130.7247210+16.86383
  • 27+105.9208727+13.66407
  • 54+100.5441554+12.97046
库存:76
