0079083A7
0079083A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 1.605"(40.77mm) 直径 0.605"(15.37mm) 高
0079083A7 数据手册
0079083A7 MAGNETICS Kool Mµ MAX Permeability (µ) AL (nH/T2) 60 81 ± 8% Inductance Grade N/A Coated Limits Coating Color Black Packaging (in) (mm) (in) OD (A) 39.88 1.570 40.77 1.605 max ID (B) 24.13 0.950 23.32 0.918 min HT (C) 14.48 0.570 15.37 0.605 max Cardboard cut-outs Box Qty= 180 pcs Physical Characteristics DC Bias min (oersteds) 80% 58.0 Part Number 79083A7 (mm) Electrical Characteristics 700 Core Marking Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 100 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 116 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 126 427 107 98.4 10,600 65 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 48.2 54.3 55.8 57.0 58.8 40% 45% 50% 60% 70% 60.2 62.1 63.7 67.3 71.5 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 44.3 22.4 56.4 35.2 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 4,800 7,300 Typical DC Bias Performance 90.0 80.0 80% 70.0 AL (nH/T2) 60.0 50.0 50% 40.0 30.0 20.0 10.0 0.0 0 200 400 600 800 1000 1200 1400 A·T Revision 10/6/2021
0079083A7 价格&库存
很抱歉,暂时无法提供与“0079083A7”相匹配的价格&库存,您可以联系我们找货
0079083A7
  • 1+88.961971+11.53117
  • 10+59.7564210+7.74557
  • 25+50.0496325+6.48739
  • 50+43.3003750+5.61256
  • 180+38.75707180+5.02366
库存:125
