0079102A7
0079102A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 4.000"(101.60mm) 直径 0.650"(16.51mm) 高
0079102A7 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 0079102A7 MAGNETICS < Kool Mµ MAX Permeability (µ) AL (nH/T2) 26 48 ± 8% Dimensions Uncoated Inductance Grade N/A Coated Limits Coating Color Black Packaging (in) (mm) (in) OD (A) 101.60 4.000 103.00 4.055 max ID (B) 57.15 2.250 55.75 2.195 min HT (C) 16.51 0.650 17.91 0.705 max Cardboard cut-outs Box Qty= 25 pcs Physical Characteristics DC Bias min (oersteds) 80% 135 700 Part Number 79102A7 (mm) Electrical Characteristics Watt Loss @ 100 kHz, 100mT max (mW/cm3) Core Marking Lot Number XXXXXX 50% 285 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 2000 181.0 2,470 358 243 86,900 510 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 82.2 96.8 100 103 108 40% 45% 50% 60% 70% 111 116 120 128 139 Temperature Rating Wound Coil Dimensions (mm) OD 112 40% Winding Factor HT 34.9 Max OD 136 Completely Full Window Max HT 55.1 Curie Temp: 500˚C Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 20,000 36,000 Revision 9/30/2021
0079102A7 价格&库存
很抱歉,暂时无法提供与“0079102A7”相匹配的价格&库存,您可以联系我们找货
0079102A7
  • 1+375.657991+48.53209
  • 10+240.3886210+31.05634
  • 25+213.7969225+27.62090
库存:5
