0079113A7
0079113A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 0.680"(17.27mm) 直径 0.280"(7.11mm) 高
0079113A7 数据手册
0079113A7 MAGNETICS AL (nH/T2) 40 24 ± 8% Part Number 79113A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 16.59 0.653 17.27 0.680 max ID (B) 10.16 0.400 9.53 0.375 min HT (C) 6.35 0.250 7.11 0.280 max Bulk Pack 4 bags/box Box Qty= 2000 pcs Physical Characteristics DC Bias min (oersteds) 80% 85.0 Lot Number XXXXXX Uncoated Electrical Characteristics 700 Core Marking XFLUX Permeability (µ) Dimensions Watt Loss @ 50 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 180 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 1250 23.0 71.2 19.2 41.2 791 6.1000 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 22.0 24.4 25.0 25.6 26.2 40% 45% 50% 60% 70% 26.8 27.6 28.3 29.7 31.4 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 18.8 10.1 23.7 15.2 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 920 1,300 Typical DC Bias Performance 25.0 80% AL (nH/T2) 20.0 50% 15.0 10.0 5.0 0.0 0 100 200 300 400 500 600 700 800 A·T Revision 10/6/2021
0079113A7 价格&库存
很抱歉,暂时无法提供与“0079113A7”相匹配的价格&库存,您可以联系我们找货
