110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0079191A7
MAGNETICS
Kool Mµ MAX
Permeability
(µ)
AL
(nH/T2)
26
60 ± 8%
Uncoated
Dimensions
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(in)
(mm)
(in)
OD (A)
57.15
2.250
58.04
2.285
max
ID (B)
26.39
1.039
25.58
1.007
min
HT (C)
15.24
0.600
16.13
0.635
max
Cardboard cut-outs
Box Qty= 80 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
135
700
Part
Number
79191A7
(mm)
Electrical Characteristics
Watt Loss
@ 100 kHz, 100mT
max(mW/cm3)
Core Marking
Lot
Number
XXXXXX
50%
285
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
163.0
514
229
125
28,600
175
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
64.6
71.2
72.9
74.1
76.3
40%
45%
50%
60%
70%
77.8
79.8
81.6
85.6
90.1
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
62.0
24.0
75.7
34.0
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
8,500
12,000
Revision 10/6/2021
很抱歉,暂时无法提供与“0079191A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+165.120901+21.45789
- 10+108.9859710+14.16301
- 25+90.2078025+11.72274
- 80+80.4925980+10.46022
