0079337A7
0079337A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 5.274"(133.96mm) 直径 1.055"(26.80mm) 高
0079337A7 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 0079337A7 Kool Mµ MAX Permeability (µ) AL (nH/T2) 26 68 ± 8% Uncoated Dimensions Inductance Grade N/A Coated Limits Coating Color Black Packaging (in) (mm) (in) OD (A) 132.56 5.219 133.96 5.274 max ID (B) 78.59 3.094 77.19 3.039 min HT (C) 25.40 1.000 26.80 1.055 max Cardboard cut-outs Box Qty= 16 pcs Physical Characteristics DC Bias min (oersteds) 80% 135 700 Part Number 79337A7 (mm) Electrical Characteristics Watt Loss @ 100 kHz, 100mT max (mW/cm3) Core Marking Lot Number XXXXXX 50% 285 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 227.0 4,710 678 324 220,000 1,250 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 110 130 135 139 145 40% 45% 50% 60% 70% 150 156 162 173 187 Temperature Rating Wound Coil Dimensions (mm) OD 146 40% Winding Factor HT 50.7 Max OD 179 Completely Full Window Max HT 78.8 Curie Temp: 500˚C Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 36,000 65,000 Revision 5/9/2022
0079337A7 价格&库存
很抱歉,暂时无法提供与“0079337A7”相匹配的价格&库存,您可以联系我们找货
0079337A7
  • 1+749.163021+97.10579
