110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0079351A7
Kool Mµ MAX
Permeability
(µ)
AL
(nH/T2)
60
51 ± 8%
Uncoated
Dimensions
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(in)
(mm)
(in)
OD (A)
23.57
0.928
24.33
0.958
max
ID (B)
14.40
0.567
13.77
0.542
min
HT (C)
8.89
0.350
9.65
0.380
max
Bulk Pack
4 bags/box
Box Qty= 720 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
58
700
Part
Number
79351A7
(mm)
Electrical Characteristics
Watt Loss
@ 100 kHz, 100mT
max(mW/cm3)
Core Marking
Lot
Number
XXXXXX
50%
116
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
2000
47.0
149
38.8
58.8
2,280
14
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
29.8
33.4
34.2
35.0
36.1
40%
45%
50%
60%
70%
36.9
38.0
38.9
41.1
43.6
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
26.7
14.2
33.5
21.4
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
1,800
2,700
Revision 12/17/2021
很抱歉,暂时无法提供与“0079351A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.401521+4.34062
