110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
0079716A7
MAGNETICS
Kool Mµ MAX
Permeability
(µ)
AL
(nH/T2)
60
73 ± 8%
Uncoated
Dimensions
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(in)
(mm)
(in)
OD (A)
50.80
2.000
51.69
2.035
max
ID (B)
31.75
1.250
30.94
1.218
min
HT (C)
13.46
0.530
14.35
0.565
max
Cardboard cut-outs
Box Qty= 90 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
58.0
700
Part
Number
79716A7
(mm)
Electrical Characteristics
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
Core Marking
Lot
Number
XXXXXX
50%
116
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
93.0
751
125
127
15,900
98
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
49.5
57.4
59.6
61.0
63.5
40%
45%
50%
60%
70%
65.5
67.7
70.1
74.9
80.3
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
56.6
24.2
72.4
40.6
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
6,400
11,000
Revision 10/7/2021
很抱歉,暂时无法提供与“0079716A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+119.828461+15.49708
