0079735A7
MAGNETICS
Kool Mµ MAX
Permeability
(µ)
AL
(nH/T2)
26
88 ± 8%
Inductance
Grade
N/A
Coated Limits
Coating
Color
Black
Packaging
(in)
(mm)
(in)
OD (A)
74.09
2.917
75.21
2.961
max
ID (B)
45.29
1.783
44.40
1.748
min
HT (C)
35.00
1.378
35.92
1.414
max
Cardboard cut-outs
Box Qty= 24 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
135
Part
Number
79735A7
(mm)
Electrical Characteristics
700
Core Marking
Lot
Number
XXXXXX
Uncoated
Dimensions
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
50%
285
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
227.0
1,550
497
184
91,400
530
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
102
114
117
119
122
40%
45%
50%
60%
70%
125
129
132
139
147
Temperature Rating
Wound Coil Dimensions (mm)
OD
91.0
40% Winding Factor
HT
55.2
Max OD
102
Completely Full Window
Max HT
65.7
Curie Temp: 500˚C
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
19,000
33,000
Typical DC Bias Performance
90
80
80%
AL (nH/T2)
70
60
50%
50
40
30
2000
3000
4000
5000
6000
A·T
Revision 10/7/2021
很抱歉,暂时无法提供与“0079735A7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+402.977531+52.38578
- 24+232.5805424+30.23472
