0079737A7
0079737A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 2.961"(75.21mm) 直径 1.414"(35.92mm) 高
0079737A7 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 0079737A7 MAGNETICS < AL (nH/T2) 60 204 ± 8% Dimensions Part Number 79737A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 74.09 2.917 75.21 2.961 max ID (B) 45.29 1.783 44.40 1.748 min HT (C) 35.00 1.378 35.92 1.414 max Cardboard cut-outs Box Qty= 24 pcs Physical Characteristics DC Bias min (oersteds) 80% 58.0 700 Lot Number XXXXXX Uncoated Electrical Characteristics Watt Loss @ 100 kHz, 100mT max (mW/cm3) Core Marking Kool Mµ MAX Permeability (µ) 50% 116 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 227.0 1,550 497 184 91,400 580 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 102 114 117 119 122 40% 45% 50% 60% 70% 125 129 132 139 147 Temperature Rating Wound Coil Dimensions (mm) OD 91.0 40% Winding Factor HT 55.2 Max OD 102 Completely Full Window Max HT 65.7 Curie Temp: 500˚C Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 19,000 33,000 Revision 10/7/2021
0079737A7 价格&库存
很抱歉,暂时无法提供与“0079737A7”相匹配的价格&库存,您可以联系我们找货
