0079908A7
0079908A7
    MAGNETICS(美磁)
    有涂层 Kool Mu MAX 铁氧体磁芯磁环 型 长度 宽 3.108"(78.94mm) 直径 0.670"(17.02mm) 高
0079908A7 数据手册
0079908A7 MAGNETICS Kool Mµ MAX Permeability (µ) AL (nH/T2) 26 37 ± 8% Dimensions Part Number 79908A7 Inductance Grade N/A Coated Limits Coating Color Black Packaging (mm) (in) (mm) (in) OD (A) 77.80 3.063 78.94 3.108 max ID (B) 49.23 1.938 48.21 1.898 min HT (C) 15.88 0.625 17.02 0.670 max Cardboard cut-outs Box Qty= 40 pcs Physical Characteristics DC Bias min (oersteds) 80% 135 700 Core Marking Lot Number XXXXXX Uncoated Electrical Characteristics Watt Loss @100 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 285 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 141.0 1,820 221 196 43,400 260 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 64.8 77.3 80.1 83.1 86.5 40% 45% 50% 60% 70% 89.2 93.2 97.0 104 113 Temperature Rating Wound Coil Dimensions (mm) OD 86.6 40% Winding Factor HT 32.3 Max OD 112 Completely Full Window Max HT 57.7 Curie Temp: 500˚C Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 13,000 23,000 Typical DC Bias Performance 40 35 80% AL (nH/T2) 30 25 50% 20 15 10 5 0 0 1000 2000 3000 4000 5000 6000 A·T Revision 10/7/2021
0079908A7 价格&库存
很抱歉,暂时无法提供与“0079908A7”相匹配的价格&库存,您可以联系我们找货
