C055051A2
C055051A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 0.530"(13.45mm) 直径 0.217"(5.51mm) 高
C055051A2 数据手册
C055051A2 MAGNETICS AL (nH/T2) 60 27 ± 8% Part Number 051A2 Inductance Grade X Coated Limits Coating Color Gray Packaging (mm) (in) (mm) (in) OD (A) 12.70 0.500 13.46 0.530 max ID (B) 7.62 0.300 6.99 0.275 min HT (C) 4.75 0.187 5.51 0.217 max Bulk Pack 4 bags/box Box Qty= 5000 pcs Physical Characteristics DC Bias min (oersteds) 80% 50.0 Lot Number XXXXXX Uncoated Electrical Characteristics 700 Core Marking MPP Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 94.0 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 1250 15.0 38.3 10.9 31.2 340 2.9140 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 17.5 19.3 19.8 20.1 20.7 40% 45% 50% 60% 70% 21.1 21.7 22.1 23.2 24.5 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT 14.6 7.66 18.2 11.5 Curie Temp: 460 ˚C Coating Temp (Continuous up to): 200 ˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 560 800 Typical DC Bias Performance 30 25 AL (nH/T2) 80% 20 50% 15 10 5 0 0 50 100 150 200 A·T 250 300 350 400 Revision 10/5/2021
C055051A2 价格&库存
很抱歉,暂时无法提供与“C055051A2”相匹配的价格&库存,您可以联系我们找货
