C055347A2
C055347A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 0.958"(24.33mm) 直径 0.380"(9.65mm) 高
C055347A2 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com C055347A2 AL (nH/T2) 200 169 ± 8% Inductance Grade X Coated Limits Coating Color Gray Packaging (in) (mm) (in) OD (A) 23.57 0.928 24.33 0.958 max ID (B) 14.40 0.567 13.77 0.542 min HT (C) 8.89 0.350 9.65 0.380 max Bulk Pack 4 bags/box Box Qty= 720 pcs Physical Characteristics DC Bias min (oersteds) 80% 15.0 Part Number 55347A2 (mm) Electrical Characteristics 1050 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 100 kHz, 100mT max (mW/cm3) Core Marking MPP Permeability (µ) 50% 28.0 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 2000 47.0 149 38.8 58.8 2,280 21 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 29.8 33.4 34.2 35.0 36.1 40% 45% 50% 60% 70% 36.9 38.0 38.9 41.1 43.6 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 460 ˚C 26.7 14.2 33.5 21.4 Coating Temp (Continuous up to): 200 ˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 1,800 2,700 Typical DC Bias Performance 180 160 80% AL (nH/T2) 140 120 50% 100 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 200 A·T Revision 12/17/2021
C055347A2 价格&库存
很抱歉,暂时无法提供与“C055347A2”相匹配的价格&库存,您可以联系我们找货
C055347A2
  • 1+131.520351+17.06894
  • 10+87.3844910+11.34092
  • 25+72.6735325+9.43170
  • 50+62.4191450+8.10087
  • 240+61.47169240+7.97791
库存:116
