C058322A2
MAGNETICS
AL
(nH/T2)
160
150 ± 8%
Part
Number
58322A2
Inductance
Grade
X
Coated Limits
Coating
Color
Khaki
Packaging
(mm)
(in)
(mm)
(in)
OD (A)
35.81
1.410
36.70
1.445
max
ID (B)
22.35
0.880
21.54
0.848
min
HT (C)
10.46
0.412
11.35
0.447
max
Cardboard cut-outs
Box Qty= 220 pcs
Physical Characteristics
DC Bias
typical (oersteds)
80%
32
Lot
Number
XXXXXX
Uncoated
Electrical Characteristics
1500
Core Marking
High Flux
Permeability
(µ)
Dimensions
Watt Loss
@ 100 kHz, 100mT
max (mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
50%
60
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
80
364
67.8
89.8
6,090
50
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
37.9
43.5
44.8
46.0
47.6
40%
45%
50%
60%
70%
48.9
50.6
52.0
55.5
59.3
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
Curie Temp: 500˚C
40.2
18.4
51.1
29.6
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
3,400
5,700
Typical DC Bias Performance
160.0
140.0
80%
120.0
AL (nH/T2)
100.0
50%
80.0
60.0
40.0
20.0
0.0
200
300
400
500
600
A·T
Revision 10/6/2021
很抱歉,暂时无法提供与“C058322A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+185.453551+23.03469
- 10+121.7061610+15.11680
- 25+100.3733525+12.46711
- 50+97.7588150+12.14236
