C058906A2
MAGNETICS
Core Marking
High Flux
Permeability
(µ)
AL
(nH/T2)
125
177± 8%
Dimensions
Part
Number
58906A2
Inductance
Grade
X
Coated Limits
Coating
Color
Khaki
Packaging
(mm)
(in)
(mm)
(in)
OD (A)
77.80
3.063
78.94
3.108
max
ID (B)
49.23
1.938
48.21
1.898
min
HT (C)
15.9
0.625
17.0
0.670
max
Cardboard cut-outs
Box Qty= 40 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
46.0
1000
Lot
Number
XXXXXX
Uncoated
Electrical Characteristics
Watt Loss
@ 100 kHz, 100mT
Max (mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
3000
141.0
1,820
221
196
43,400
360
50%
81.0
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
64.8
77.3
80.1
83.1
86.5
40%
45%
50%
60%
70%
89.2
93.2
97.0
104
113
Temperature Rating
Wound Coil Dimensions (mm)
OD
86.6
40% Winding Factor
HT
32.3
Max OD
112
Completely Full Window
Max HT 57.7
Curie Temp: 500˚C
Coating Temp (Continuous up to):
200˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
13,000
24,000
Typical DC Bias Performance
180
80%
160
AL (nH/T2)
140
120
50%
100
80
60
40
400
600
800
1000
1200
1400
1600
1800
2000
A·T
Revision 10/7/2021
很抱歉,暂时无法提供与“C058906A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+840.642751+108.30357
