MIKROE-3920
MIKROE-3920
    MIKRO
    电容性 智能,智慧,发光二极管,图形 TFT - 彩色 4.3"(109.22mm) 800 x 480(WVGA)
MIKROE-3920 数据手册
Mikromedia 4 for Kinetis Capacitive FPI with bezel PID: MIKROE-3920 Rich with peripherals Mikromedia 4 for Kinetis CAPACITIVE FPI with bezel is not limited to multimedia-based applications only. USB, WiFi and RF connectivity options, digital motion sensor, battery charging functionality, piezo-buzzer, SD card reader, RTC, and much more expands its use beyond the multimedia. Mikromedia 4 for Kinetis CAPACITIVE FPI with bezel has three mikroBUS™ Shuttle connectors, a brand-new addition to the mikroBUS™ standard in the form of a 2x8-pin IDC header with 1.27mm (50mil) pitch. mikroBUS™ Shuttle extension board is an add-on board equipped with the conventional mikroBUS™ socket, which ensures compatibility with 894 Click boards™. Awesome graphics on MCU driven TFT Mikromedia 4 for Kinetis CAPACITIVE FPI with bezel is a compact development board designed as a complete solution for the rapid development of multimedia and GUI-centric applications. By featuring a 4.3" TFT display with capacitive touch screen driven by the powerful graphics controller that can display the 24-bit color palette (16.7 million colors), along with a DSPpowered embedded sound CODEC IC, represents a perfect solution for any type of multimedia application. Develop-on & build-in the same board Mikromedia 4 for Kinetis CAPACITIVE FPI (FPI stands for Front Panel Integration) with bezel is designed as the complete solution. It can be implemented directly into any project, with no additional hardware modifications. At its core, there is a powerful 32-bit MK66FX1M0VLQ18 microcontroller from NXP Semiconductors, which provides sufficient processing power for the most demanding tasks. Board has a TFT display with a bezel around it and it is ideal for handheld devices. For most uses, a nice casing is all that is needed to turn this product into a high-performance, feature-rich device. This board requires the use of an external programmer and debugger, preferably CODEGRIP or mikroProg. The microcontroller can be programmed and debugged over the JTAG/SWD compatible 2x5 pin header, labeled as PROG/DEBUG. Specifications Type mikromedia Architecture ARM (32-bit) Display size 4.3" Resolution 480x272px Graphic controller SSD1963 Touch Screen Capacitive Silicon Vendor NXP mikroBUS No. 2 Frame Type Bezel Features Battery for RTC,USB Type C,USB Host,SD Card,RF,ON/OFF switch,MP3,External DC source,Buzzer,Battery Powered,Batt. Chg. when OFF,Accel Display type mikromedia Downloads Mikromedia 4 for Kinetis Capacitive FPI with bezel schematic Mikromedia 4 for Kinetis Capacitive FPI with bezel example on libstock Mikromedia 4 for Kinetis Capacitive FPI with bezel Manual Mikromedia 4 for Kinetis Capacitive FPI with bezel 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-3920 价格&库存
很抱歉,暂时无法提供与“MIKROE-3920”相匹配的价格&库存,您可以联系我们找货
