Mikromedia 5 for Kinetis Capacitive
FPI with bezel
PID: MIKROE-3918
Rich with peripherals
Mikromedia 5 for Kinetis Capacitive FPI with bezel is not limited to multimedia-based
applications only. USB, WiFi and RF connectivity options, digital motion sensor, battery
charging functionality, piezo-buzzer, SD card reader, RTC, and much more expands its use
beyond the multimedia.
Mikromedia 5 for Kinetis CAPACITIVE FPI with bezel has three mikroBUS™ Shuttle connectors, a
brand-new addition to the mikroBUS™ standard in the form of a 2x8-pin IDC header with
1.27mm (50mil) pitch. mikroBUS™ Shuttle extension board is an add-on board equipped with
the conventional mikroBUS™ socket, which ensures compatibility with 894 Click boards™.
Awesome graphics on MCU driven TFT
Mikromedia 5 for Kinetis Capacitive FPI with bezel is a compact development board designed as
a complete solution for the rapid development of multimedia and GUI-centric applications. By
featuring a 5" TFT display with capacitive touch screen driven by the powerful graphics
controller that can display the 24-bit color palette (16.7 million colors), along with a DSPpowered embedded sound CODEC IC, represents a perfect solution for any type of multimedia
application.
Develop-on & build-in the same board
Mikromedia 5 for Kinetis CAPACITIVE FPI (FPI stands for Front Panel Integration) with bezel is
designed as the complete solution. It can be implemented directly into any project, with no
additional hardware modifications. At its core, there is a powerful 32-bit MK66FX1M0VLQ18
microcontroller from NXP Semiconductors, which provides sufficient processing power for the
most demanding tasks. Board has a TFT display with a bezel around it and it is ideal for
handheld devices. For most uses, a nice casing is all that is needed to turn this product into a
high-performance, feature-rich device. This board requires the use of an external programmer
and debugger, preferably CODEGRIP or mikroProg. The microcontroller can be programmed
and debugged over the JTAG/SWD compatible 2x5 pin header, labeled as PROG/DEBUG.
Specifications
Type
mikromedia
Architecture
ARM (32-bit)
Display size
5"
Resolution
800x480px
Graphic controller
SSD1963
Touch Screen
Capacitive
Silicon Vendor
NXP
mikroBUS No.
3
Frame Type
Bezel
Features
Battery for RTC,WiFi,USB Type C,USB Host,SD
Card,RF,ON/OFF switch,MP3,External DC
source,Buzzer,Battery Powered,Batt. Chg.
when OFF,Accel
Display type
mikromedia
Downloads
Mikromedia 5 for Kinetis Capacitive FPI with bezel schematic
Mikromedia 5 for Kinetis Capacitive FPI with bezel example on libstock
Mikromedia 5 for Kinetis Capacitive FPI with bezel 2D and 3D files
Mikromedia 5 for Kinetis Capacitive FPI with bezel manual
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-3918”相匹配的价格&库存,您可以联系我们找货
