CAN FD 3 Click
PID: MIKROE-3992
CAN FD 3 Click is a add-on board based on TLE9251V CAN network transceiver, designed for
HS CAN networks up to 5 Mbit/s in automotive and industrial applications. As an interface
between the physical bus layer and the CAN protocol controller, the TLE9251V drives the
signals to the bus and protects the microcontroller against interferences generated within the
network. Given all the features its components offer, the CAN FD Click is best used for for
infotainment applications, gateway modules, body control modules (BCM) or engine control
units (ECUs).
CAN FD 3 Click board™ is supported by a mikroSDK compliant library, which includes functions
that simplify software development. This Click board™ comes as a fully tested product, ready
to be used on a system equipped with the mikroBUS™ socket.
Specifications
Type
CAN,CAN FD
Applications
CAN FD Click is best used for for infotainment
modules (BCM) or engine control units (ECUs).
On-board modules
On-board modules TLE9251V, a transceiver
designed for HS CAN networks up to 5 Mbit/s
in automotive and industrial applications from
Infineon
Key Features
Key Features Very low electromagnetic
emission (EME) for chokeless usage, Dual
Power Supply Solution
Interface
UART
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
CAN FD 3 click example on Libstock
CAN FD 3 click schematic
TLE9251V datasheet
CAN FD 3 click 2D and 3D files
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-3992”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+134.80712
- 5+132.10994
