MIKROE-4039
MIKROE-4039
    MIKRO
    INA260 电流监控器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4039 数据手册
VCP Monitor Click PID: MIKROE-4039 The VCP Monitor Click is add-on board power monitor system. This Click board™ is based on INA260AIPWR - precision digital current and power monitor with low-drift, integrated precision shunt resistor, from Texas Instruments. Therefore, using VCP Monitor Click, current, voltage and power can be monitored. The integrated current-sensing resistor ensures measurement stability over temperature as well as simplifying printed-circuit board layout difficulties common in high precision current sensing measurements. VCP Monitor click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Current sensor,Measurements Applications VCP Monitor click click is a perfect solution for the development of the Power Managment system, Battery Chargers and Power Supplies. On-board modules NA260AIPWR, a digital-output, current, power, and voltage monitor with an I2C and SMBus™-compatible interfacefrom Texas Instruments Key Features Current Sense Resistance: 2 mΩ, Tolerance Equivalent to 0.1%, 15-A Continuous From –40°C to +85°C, 16 Programmable Addresses. Interface I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads VCP Monitor click example on Libstock VCP Monitor click 2D and 3D files INA260 datasheet VCP Monitor click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4039 价格&库存
很抱歉,暂时无法提供与“MIKROE-4039”相匹配的价格&库存,您可以联系我们找货
MIKROE-4039
  • 1+214.956251+27.91100
库存:1
MIKROE-4039
    • 1+221.943601+28.26740
