MIKROE-4046
MIKROE-4046
    MIKRO
    FORCE 2 CLICK
MIKROE-4046 数据手册
Force 2 Click PID: MIKROE-4046 Force 2 Click is a mikroBUS™ add-on board with circuitry for implementing Honeywell’s FSS1500NGT Series force sensors into your projects (with a single zone force sensing resistor included with the click). This Click board™ utilizes FSS1500NGT force sensor which is designed to be one of the most reliable force sensor available as illustrated by 20 million Mean Cycles to Failure (MCTF) at 25 °C [77 °F] rating. This low profile Surface Mount Technology (SMT) sensor allows for automated assembly on a printed circuit board, often helping the customer to reduce assembly costs, while maintainging precise and reliable force sensing performance in a compact commercial-grade package. Force 2 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Force Applications FSS1500NGT sensor is used in medical and industrial purposes, like infusionand ambulatory non-invasive pumps, kidney dialysis machines, load and compression sensing, variable tension control, robotic endeffector, etc. On-board modules FSS015NGT Honeywell’s FSS-SMT Series force sensor Key Features FSS015NGT force sensor on it and the force sensing range is 0-15N with overforce up to 45N Interface Analog ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Force 2 click example on Libstock Force 2 click 2D and 3D files Force 2 click schematic FSS1500NGT datasheet Powered by TCPDF (www.tcpdf.org)
MIKROE-4046 价格&库存
很抱歉,暂时无法提供与“MIKROE-4046”相匹配的价格&库存,您可以联系我们找货
MIKROE-4046
  • 1+1450.64751
  • 5+1421.63456
库存:1
MIKROE-4046
  • 1+1429.135741+178.75214
