MIKROE-4049
MIKROE-4049
    MIKRO
    EKMC1606112,TLP241A 无源红外(PIR) 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4049 数据手册
Motion 3 Click PID: MIKROE-4049 Motion 3 Click is a Click board™ based on EKMC1606112, PIR motion sensor from Panasonic Corporation that's used as human motion detector. Also featured on Motion 3 Click bord is TLP241A photorelay from Toshiba that is used to provide a reinforced galvanic isolation for the external signals used to drive some external high power electronic equipment when motion is detected. It's allowing up to 40V between the SSR contacts in OFF state, and currents up to 2A while in ON state, thanks to a very low ON-state resistance. Motion 3 Click board™ is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Motion Applications Alarm systems, light switch controllers, automatic doors and similar systems where human presence needs to be detected. On-board modules EKMC1606112 the PIR motion sensor Key Features 128 detection zones, wide detection range and maximum range between 12 and 17 m Interface GPIO ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Motion 3 click example on Libstock EKMC160611 datasheet Motion 3 click schematic Motion 3 click 2D and 3D files Powered by TCPDF (www.tcpdf.org)
MIKROE-4049 价格&库存
很抱歉,暂时无法提供与“MIKROE-4049”相匹配的价格&库存,您可以联系我们找货
MIKROE-4049
  • 1+325.800011+42.27228
MIKROE-4049
  • 1+315.842801+40.22670
库存:5
