MIKROE-4047
MIKROE-4047
    MIKRO
    NAU7802 称重计 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4047 数据手册
Load Cell 2 Click PID: MIKROE-4047 Load cell 2 Click is a weight measurement click which utilizes a load cell element, in order to precisely measure the weight of an object. The Load Cell 2 Click can be used with the strain gauge type of load cells with external differential reference voltage range from 0.1V to 5V. The strain gauge load cell is typically a circuit made of four strain gauges, connected in the Wheatstone bridge configuration. Very small voltage changes need to be accurately detected and converted into a digital form. The Load Cell 2 Click is based around the NAU7802, which is a 24-bit analog-to-digital converter, operated via a simple I2C command, from Nuvoton. This sensor has many features that make it a perfect solution for small designs. One of these features is certainly its high level of integration that allows a minimal number of external components. Load Cell 2 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Force Applications NAU7802 provides a complete front-end solution for bridge/sensor measurement such as in weigh scales, strain gauges, and many other high resolution, low sample rate applications. On-board modules NAU7802 24-Bit Dual-Channel ADC For Bridge Sensors Key Features NAU7802 is a precision low-power 24-bit analog-to-digital converter (ADC), with an onboard low-noise programmable gain amplifier (PGA), onboard RC or Crystal oscillator, and a precision 24-bit sigma-delta (ΣΔ) analog to digital converter (ADC) Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Load Cell 2 click example on Libstock Load Cell 2 click 2D and 3D files NAU7802 datasheet Load Cell 2 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4047 价格&库存
很抱歉,暂时无法提供与“MIKROE-4047”相匹配的价格&库存,您可以联系我们找货
