MIKROE-4058
MIKROE-4058
    MIKRO
    EL357N-G,MCP3202,Si7858BDP 电池监控器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4058 数据手册
Balancer 2 Click PID: MIKROE-4058 Balancer 2 Click is an overvoltage protection device for a 2-series cell lithium-ion battery. Click contains two separate overvoltage battery detection circuits and automatic cell imbalance correction. It can be used for various applications, power tools, portable equipment, and instrumentation, to energy storage systems (ESS), while providing the output voltage at the same time. By utilizing an externally connected power supply, it can charge 2-cell Li-Ion batteries. The Click board™ is supported by the mikroSDK compliant library, which includes functions that simplify software development. The Click board™ comes as a fully tested product, ready to be used on a system equipped with mikroBUS™. Specifications Type Battery charger Applications Balancer 2 click can be used for voltage monitor, power tools, battery balancing, portable equipment and instrumentation, to energy storage systems (ESS) On-board modules MCP3202, Dual Channel 12-Bit A/D Converter with SPI Serial Interface, from Microchip. Key Features Over-voltage protection, optocoupled outputs, independent cell voltage readings Interface GPIO,SPI ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads MCP3202 datasheet EL357N-G datasheet Balancer 2 click 2D and 3D files Balancer 2 click example on Libstock Balancer 2 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4058 价格&库存
很抱歉,暂时无法提供与“MIKROE-4058”相匹配的价格&库存,您可以联系我们找货
MIKROE-4058
