MIKROE-4082
MIKROE-4082
    MIKRO
    MCP3221,MP2632B 电池充电器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4082 数据手册
PowerBank Click PID: MIKROE-4082 PowerBank Click is a USB charging expansion board which can be used for creating power bank devices or adding charging option to your device. For battery charging management this board uses MP2632B a highly integrated 3A Lu-ion and Li-polymer battery charger from Microchip. In addition to battery charger PowerBank Click also has a MCP3221 analog to digital converter, which is serving for monitoring battery voltage over I2C interface. Beside battery charging and monitoring feature, this board also has an operation section button, notification LEDs for operational mode selection and battery status. Power banks are popular for charging USB charged devices and can be used as a power supply for various USB powered devices such as lights and small fans. PowerBank Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Battery charger Applications Battery Charger Applications, Power-Bank Applications for Smartphones, Tablets and Other Portable Devices On-board modules MP2632B switch-mode battery charger Key Features Switch-mode battery charger with system power-path management designed for singlecell Li-ion or Li-polymer batteries Interface I2C ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads PowerBank click 2D and 3D files MCP3221 datasheet MP2632B datasheet PowerBank click example on Libstock PowerBank click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4082 价格&库存
很抱歉,暂时无法提供与“MIKROE-4082”相匹配的价格&库存,您可以联系我们找货
