MIKROE-4090
MIKROE-4090
    MIKRO
    ADS1115,NC7S14M5X,TPS61041 随机数字发生器 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4090 数据手册
RNG Click PID: MIKROE-4090 RNG Click is a random number generator (RNG) is a device that generates a sequence of numbers or symbols that cannot be reasonably predicted better than by a random chance. This Click board™ is true hardware random-number generator (HRNG), which generate genuinely random numbers. Random number generators have applications in gambling, statistical sampling, computer simulation, cryptography, completely randomized design, and various other areas. RNG Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Encryption Applications Gambling, statistical sampling, computer simulation, cryptography, completely randomized design, and various other areas. On-board modules RNG Click uses the noise generator analog circuitry, NC7S14M5X inverter, from Fairchild Semiconductor and the ADS1115 - 16BIT sigma-delta ADC, from Texas Instruments Key Features Random number generator from the analogue signal input. Range of +18V power supply for the number generator range. Interface I2C ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V,5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads RNG click example on Libstock RNG click 2D and 3D files TPS61040 datasheet ADS1113 datasheet RNG click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4090 价格&库存
很抱歉,暂时无法提供与“MIKROE-4090”相匹配的价格&库存,您可以联系我们找货
