Analog MUX Click
PID: MIKROE-4111
Analog MUX Click is a Click board™ that switches one of the sixteen inputs to one output. It
employs the CD74HC4067, a High-Speed CMOS Logic 16-Channel Analog
Multiplexer/Demultiplexer, produced by Texas Instruments. It offers rail-to-rail operation,
allowing the input signal to swing up (and down) to the voltage of the power supply, with no
distortion. Features such as the low on-resistance and low input current leakage, fast and
balanced propagation delay and transition times and break-before-make switching action make
this circuit a perfect solution for various switching applications, analog and digital signals.
Analog MUX click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be
used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Measurements,Port expander
Applications
Automatization and process control,
programmable logic controllers, digital
multimeters, battery monitoring, and other
applications that require analog signal
switching.
On-board modules
CD74HC4067, a high-speed CMOS logic
16-channel analog multiplexer/demultiplexer,
Key Features
leakage, fast and balanced propagation delay
and transition times, break-before-make
switching action
Interface
GPIO
ClickID
No
Compatibility
mikroBUS™
Click board size
L (57.15 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click Boards™
Downloads
Analog Mux click 2D and 3D files
CD74HC4067 datasheet
Analog Mux click example on Libstock
Analog Mux click schematic
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+70.461501+9.13316
