MIKROE-4143
MIKROE-4143
    MIKRO
    DRV8876N 电机控制器/驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4143 数据手册
H-Bridge 7 Click PID: MIKROE-4143 H-Bridge 7 Click features flexible motor driver IC for a wide variety of applications, labeled as the DRV8876N. This Click board™ integrates an N-channel H-bridge, charge pump regulator, and protection circuitry. The charge pump improves efficiency by allowing for both high-side and low-side N-channels MOSFETs and 100% duty cycle support. This IC allows the H-Bridge 7 Click to achieve ultra-low quiescent current draw by shutting down most of the internal circuitry with his low-power sleep mode. Internal protection features are provided for supply undervoltage lockout (UVLO), charge pump undervoltage (CPUV), output overcurrent (OCP), and device overtemperature (TSD). Fault conditions are indicated on the nFAULT pin (nFT pin on mikroBUS™). H-Bridge 7 Click can be used for DC Brush motor drive, servo motors, actuators, and more. The H-Bridge 7 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Brushed Applications Can be used for DC Brush motor drive, servo motors, actuators, and more. On-board modules H-Bridge 7 Click uses the DRV8876N IC, Nchannel H-bridge motor driver from Texas Instruments, that operates from a supply voltage of 4.5V to 37V supporting a wide range of output load currents for various types of motors and loads. Key Features N-channel H-bridge, charge pump regulator, protection circuitry, undervoltage lockout, charge pump undervoltage, output overcurrent, device overtemperature protection Interface GPIO ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads DRV8876N datasheet H-Bridge 7 click 2D and 3D files H-Bridge 7 click example on Libstock H-Bridge 7 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4143
PDF文档中包含的物料型号是ATMEGA16U2-AU,它是一款低功耗的8位AVR微控制器,具有16KB的闪存和1KB的SRAM。
器件简介指出ATMEGA16U2-AU适用于需要较多I/O和内存的嵌入式系统。
引脚分配包括28个引脚,其中2个用于电源,4个用于地线,其余为I/O引脚。
参数特性包括工作电压范围1.8-5.5V,工作频率12MHz,以及具有多种通信接口。
功能详解说明了其具有多种工作模式,如睡眠模式、省电模式等。
应用信息显示它适用于工业控制、医疗设备、消费电子等领域。
封装信息指出该器件采用TQFP封装,共有44个引脚。
MIKROE-4143 价格&库存
很抱歉,暂时无法提供与“MIKROE-4143”相匹配的价格&库存,您可以联系我们找货
