MIKROE-4127
MIKROE-4127
    MIKRO
    NPA-201 压力 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4127 数据手册
Altitude 4 Click PID: MIKROE-4127 Altitude 4 Click introduces an absolute pressure sensor with digital output for low-cost applications labeled as NPA-201. Altitude 4 click employs a MEMS pressure sensor with a signalconditioning IC to provide accurate pressure measurements from 260 to 1260 mBar. Measurement values are provided at the digital output pins through an I2C interface. This sensor provides NPA-201 Digital Output Absolute Pressure Sensor provides low power consumption and compact size, making it ideal for battery-powered and mobile applications or any application where size is a constraint. In today’s growing market for portable electronics and wearables with multiple parameters being measured, many applications require an accurate measurement of barometric pressure to determine factors such as altitude. Altitude 4 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Altitude,Pressure Applications Pressure sensor for mobile devices, indoor and outdoor navigation, enhancement of GPS navigation, altimeter and barometer for portable devices, weather station equipment, leisure and sports, Hard Disk Drive (HDD), weather forecast. On-board modules Altitude 4 Click uses the NPA-201 IC, an absolute pressure sensor with digital output for low-cost applications, from Amphenol Advanced Sensors. Key Features Barometric pressure sensing applications for sports activity identification, mobile indoor/outdoor navigation, altitude-hold and stabilization in drones, and other Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Altitude 4 click 2D and 3D files NPA-201 datasheet Altitude 4 click example on Libstock Altitude 4 click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4127 价格&库存
很抱歉,暂时无法提供与“MIKROE-4127”相匹配的价格&库存,您可以联系我们找货
MIKROE-4127
  • 1+102.435501+13.04650
库存:2
