MIKROE-4148
MIKROE-4148
    MIKRO
    TMD37253 光 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4148 数据手册
Light mix-sens Click PID: MIKROE-4148 Light mix-sens Click is carrying TMD37253, an advanced proximity measurement, color sense (RGBC+IR), and digital ambient light sensing (ALS) device. The TMD37253 slim module package has been designed to accommodate a “single hole” aperture approach that incorporates an IR LED and factory calibrated LED driver. The proximity detection feature provides object detection (e.g., mobile device screen to the user’s ear) by photodiode detection of reflected IR energy (sourced by the integrated LED). The ALS detection feature provides photopic light intensity data. The color photodiodes have UV and IR blocking filters and a dedicated data converters producing 16-bit data. This architecture allows applications to accurately measure ambient light which enables devices to calculate illuminance and color temperature to control display backlight and chromaticity. Light mix-sens Click board™ is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Optical Applications Can be used for ambient light sensing, single hole proximity sensing, mobile phone touch screen disable, color temperature sensing to assist backlight, camera, and flash control. On-board modules Light mix-sens Click uses the TMD37253 IC, an advanced proximity measurement, color sense (RGBC+IR), and digital ambient light sensing (ALS) device, from AMS. Key Features Accurate color temperature and ambient light sensing, UV / IR blocking filters, 46° Average FOV, Photopic ambient light sensing (ALS), Programmable gain and integration time, Reduced power consumption. Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Light mix-sens click example on Libstock Light mix-sens click 2D and 3D files TMD37253 datasheet Light mix-sens click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4148 价格&库存
很抱歉,暂时无法提供与“MIKROE-4148”相匹配的价格&库存,您可以联系我们找货
