MIKROE-4174
MIKROE-4174
    MIKRO
    TM4C129XNCZAD 用于 TIVA CAPACITIVE 的 mikromedia 4 - MCU 32-位 评估板 - 嵌入式
MIKROE-4174 数据手册
Mikromedia 4 for TIVA Capacitive PID: MIKROE-4174 Rich with peripherals Mikromedia 4 for TIVA CAPACITIVE is not limited to multimedia-based applications only. USB, digital motion sensor, battery charging functionality, SD card reader and much more expands its use beyond the multimedia. Two standardized 1x26 pin headers expose the available MCU pins to the user, adding another layer of expandability. By using mikromedia 4 shield, connectivity can be further expanded with several mikroBUS™ sockets, additional connectors, peripherals, and so on. Awesome graphics on MCU driven TFT Mikromedia 4 for TIVA CAPACITIVE is a compact development board designed as a complete solution for the rapid development of multimedia and GUI-centric applications. By featuring a 4.3" TFT display with capacitive touch screen driven by the powerful graphics controller that can display the 24-bit color palette (16.7 million colors), along with a DSP-powered embedded sound CODEC IC, represents a perfect solution for any type of multimedia application. Develop-on & build-in the same board Mikromedia 4 for TIVA CAPACITIVE is designed as the complete solution which can be implemented directly into any project, with no additional hardware modifications required. At its core, there is a powerful 32-bit TM4C129XNCZADI3 microcontroller, produced by Texas Instruments, which provides sufficient processing power for the most demanding tasks. Four mounting holes at all four corners allow simple installation with mounting screws. For most applications, a nice stylish casing is all that is needed to turn the Mikromedia 4 for TIVA CAPACITIVE development board into a fully functional, high-performance, feature-rich device. Specifications Type mikromedia Architecture ARM (32-bit) Display size 4.3" Resolution 480x272px Touch Screen Capacitive Frame Type Standard Features External DC source,USB Type C,USB Host,Temperature sensor,SD Card,RGB LED,RF,Optical sensor,ON/OFF switch,MP3,IR receiver,Buzzer,Battery Powered,Battery for RTC,Batt. Chg. when OFF,Accel Display type mikromedia Downloads Mikromedia 4 for TIVA Capacitive example on libstock Mikromedia 4 for TIVA Capacitive 2D and 3D files Mikromedia 4 for TIVA Capacitive schematic Mikromedia 4 for TIVA Capacitive manual Powered by TCPDF (www.tcpdf.org)
MIKROE-4174 价格&库存
很抱歉,暂时无法提供与“MIKROE-4174”相匹配的价格&库存,您可以联系我们找货
MIKROE-4174
  • 1+2205.690681+285.20122
MIKROE-4174
  • 1+1740.848651+225.09600
库存:1
