MIKROE-4241
MIKROE-4241
    MIKRO
    I2C 接口 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4241 数据手册
8-pin I2C Click PID: MIKROE-4241 8-pin I2C Click is a compact add-on board that represents a breakout board that simplifies the connection of add-on boards with 8 pin Female Connector to mikroBUS™ socket. This board can be used as I2C Adapter with no main component on itself, with only an on-board connector for connection establishing. 8-pin I2C Click has no regional restrictions, no need for special permits, and it is possible to use this Click board™ worldwide. Being compatible with MFI (Made for iPod) is the most important feature of the 8-pin I2C Click board™ which ensures its proper operation with additional Apple accessories. This Click board™ is suitable for expanding the connectivity of the development system with the mikroBUS™, and ideal for communication with numerous devices that share the identical slave address on the same bus. 8-pin I2C Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Adapter Applications Can be used for for expanding the connectivity of the development system with the mikroBUS™, and ideal for communication with numerous devices that share the identical slave address on the same bus. On-board modules 8-pin I2C Click is a compact add-on board that represents a breakout board that simplifies the connection of add-on boards with 8 pin Female Connector to mikroBUS™ socket. Key Features MFI compatibility, no regional restrictions, expanding connectivity, retaining a perfect connection quality at all times, and more. Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads 8-pin I2C click 2D and 3D files 8-pin I2C click example on Libstock 8-pin I2C click schematic Powered by TCPDF (www.tcpdf.org)
MIKROE-4241 价格&库存
很抱歉,暂时无法提供与“MIKROE-4241”相匹配的价格&库存,您可以联系我们找货
MIKROE-4241
  • 1+70.703781+9.14743
MIKROE-4241
    • 1+63.87848
    • 5+62.59758
    库存:18
