Surface temp 2 Click
PID: MIKROE-4266
Surface temp 2 Click is a compact add-on board that contains a high accuracy temperature
sensor offering breakthrough performance over a wide industrial temperature range. This
board features the ADT7422, a 16-bit I2C temperature sensor from Analog Devices. It features
the internal bandgap reference and a precision ADC, it provides a 16-bit temperature result
with a resolution of 0.0078°C, and an accuracy of up to ±0.1°C across the temperature range
of 25°C to 50°C without the need for calibration. This makes the Surface Temp Click an
excellent choice for RTD and thermistor replacement, medical equipment, food transportation
and storage, environmental monitoring, HVAC, and other applications.
Surface temp 2 Click is supported by a mikroSDK compliant library, which includes functions
that simplify software development. This Click board™ comes as a fully tested product, ready
to be used on a system equipped with the mikroBUS™ socket.
Specifications
Type
Temperature & humidity
Applications
Can be used for RTD and thermistor
transportation and storage, environmental
On-board modules
Surface temp 2 Click is based on the ADT7422,
a high accuracy 16-bit digital temperature
sensor with programmable interrupt and
critical temperature indicator from Analog
Devices.
Key Features
Low power consumption, no calibration
needed, long-term stability and reliability, high
accuracy for industrial, instrumentation, and
medical applications, and more.
Interface
I2C
ClickID
No
Compatibility
mikroBUS™
Click board size
M (42.9 x 25.4 mm)
Input Voltage
3.3V or 5V
Resources
mikroBUS™
mikroSDK
Click board™ Catalog
Click boards™
Downloads
ADT7422 datasheet
Surface Temp 2 click 2D and 3D files
Surface Temp 2 click schematic
Surface Temp 2 click example on Libstock
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“MIKROE-4266”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+146.08531
- 5+143.16944
