MIKROE-4270
MIKROE-4270
    MIKRO
    MA302 旋转角度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4270 数据手册
Angle 5 Click PID: MIKROE-4270 Angle 5 Click is a compact add-on board that detects the absolute angular position of a permanent magnet, typically a diametrically magnetized cylinder on a rotating shaft. This board features the MA302, a 12-bit digital contactless angle sensor with ABZ and UVW incremental outputs from Monolithic Power Systems. The MA302 features an ABZ encoder, UVW pole pair emulation, fast data acquisition, and processing which provides accurate angle measurement at speeds from 0 to 60,000 rpm, and a magnetic field strength detection with programmable thresholds. This Click board™ is suitable for various applications such as detecting the absolute rotor position of a brushless motor in real-time, even without a target magnet, by measuring the fringe field of the rotor. Angle 5 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Magnetic Applications Can be used for various applications such as detecting the absolute rotor position of a brushless motor in real-time, even without a target magnet, by measuring the fringe field of the rotor. On-board modules Angle 5 Click is based on the MA302, a 12-bit digital contactless angle sensor with ABZ and UVW incremental outputs from Monolithic Power Systems. Key Features Fast data acquisition, magnetic field strength detection, contactless sensing for long life, supported both end-of-shaft and off-axis, and many more. Interface SPI ClickID No Compatibility mikroBUS™ Click board size L (57.15 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click Boards™ Downloads Angle 5 click 2D and 3D files MA302 datasheet Angle 5 Click schematic Angle 5 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4270 价格&库存
很抱歉,暂时无法提供与“MIKROE-4270”相匹配的价格&库存,您可以联系我们找货
MIKROE-4270
  • 1+194.043591+25.22504
库存:2
