MIKROE-4276
MIKROE-4276
    MIKRO
    TSD-10 浊度 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4276 数据手册
Turbidity Click PID: MIKROE-4276 Turbidity Click is an adapter Click board™, used to interface a compatible turbidity sensor with the host MCU. This board features one 1x3 2.5mm connector suitable for connecting a TSD-10 Turbidity Sensor via an additional 3-wire cable for Turbidity Click specially made for this purpose. It allows users to upgrade their projects with a sensor that senses the cloudiness or haziness of a fluid caused by large numbers of individual particles invisible to the naked eye. This sensor also measures temperature as well as turbidity. Turbidity Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Adapter,Environmental Applications Can be used to senses the cloudiness or haziness of a fluid caused by large numbers of individual particles invisible to the naked eye On-board modules Turbidity Click is adapter with socket for the TSD-10 Turbidity Sensor Key Features Low power consumption, high performance, allowing sensing of the cloudiness or haziness of a fluid, I2C configurable analog-to-digital converter, suitable for both mikroBUS™ power rails, and more Interface I2C ClickID No Compatibility mikroBUS™ Click board size S (28.6 x 25.4 mm) Input Voltage 3.3V or 5V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads MCP3221 datasheet Turbidity click 2D and 3D files Turbidity click schematic Turbidity click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4276 价格&库存
很抱歉,暂时无法提供与“MIKROE-4276”相匹配的价格&库存,您可以联系我们找货
