MIKROE-4282
MIKROE-4282
    MIKRO
    ADS1247 模数转换器(ADC) 数据采集 mikroBUS™ Click™ 平台评估扩展板
MIKROE-4282 数据手册
RTD 2 Click PID: MIKROE-4282 RTD 2 Click is a compact add-on board used for applications with resistive elements that change resistance over temperature. This board features the ADS1247, 24-bit analog-to-digital converter with a programmable gain amplifier (PGA) for sensor measurement applications from Texas Instruments. It features a precision delta-sigma (ΔΣ) ADC with a single-cycle settling digital filter, and an internal oscillator, but also provides a low-drift voltage reference, and two matched programmable excitation current sources (IDACs). Besides, an input multiplexer integrates sensor burn-out detection, voltage bias for thermocouples, system monitoring, and general-purpose digital I/Os. This Click board™ is suitable for temperature sensor measurements such as RTDs, thermocouples, and thermistors, for pressure measurements, flow meters, factory automation, and process control, and many more. RTD 2 Click is supported by a mikroSDK compliant library, which includes functions that simplify software development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with the mikroBUS™ socket. Specifications Type Temperature & humidity Applications Can be used for temperature sensor measurements such as RTDs, thermocouples, and thermistors, for pressure measurements, flow meters, factory automation, and process control, and many more. On-board modules RTD 2 Click is based on the ADS1247, a highly integrated 24-bit data converters with a programmable gain amplifier (PGA) for sensor measurement applications from Texas Instruments. Key Features Programmable Data Rates, 50/60 Hz rejection, excitation current sources (iDACs), GPIO, PGA, internal temperature sensor, self and system calibration, and more. Interface SPI ClickID No Compatibility mikroBUS™ Click board size M (42.9 x 25.4 mm) Input Voltage 3.3V Resources mikroBUS™ mikroSDK Click board™ Catalog Click boards™ Downloads ADS1247 datasheet RTD 2 click schematic RTD 2 click 2D and 3D files RTD 2 click example on Libstock Powered by TCPDF (www.tcpdf.org)
MIKROE-4282 价格&库存
很抱歉,暂时无法提供与“MIKROE-4282”相匹配的价格&库存,您可以联系我们找货
MIKROE-4282
  • 1+254.269001+33.04290
库存:5
MIKROE-4282
  • 1+255.177381+33.16096
库存:4
